I use a red spray Muscle Grease. I think I saw that on South Main Auto on YT.Make sure to grease the hub and inside of new rotor
It's not how hard to hit, it's where you hit in order to send shocks/vibrations through the mating surface and break up the rust. That's why it's best to use a heavy hammer, but don't swing it hard, instead of a light one, or a dead blow and swinging like a mad man.So how hard can one bang with a sledgehammer without worrying about damage to a hub or bearing?
Inner tie rod end jam nut that I couldn't break free for anything. 30 to 60 seconds with propane freed right up!I've found that heating frozen parts- even with propane or pag helps break that bond.
So where is the best place to hit the rotor so that the rotor will come off but not damage the hub/bearing.It's not how hard to hit, it's where you hit in order to send shocks/vibrations through the mating surface and break up the rust. That's why it's best to use a heavy hammer, but don't swing it hard, instead of a light one, or a dead blow and swinging like a mad man.
OP used a dead blow hammer, so there were minimal shocks/vibrations going though the rotor and the hub. That is why he broke the rotor instead of freeing it. The place he was hitting also contributed to that.
I'm thinking a Lithium Bearing Grease may be the best since it has a high melting point . I would not suggest Fluid Film since it drips alot in warm temps and you sure dont want it getting on the Rotors .ANTISEIZE (in reasonable quantities) is your friend, here. I‘m a big fan of Deep Creep, that stuff seems to work itself into rust really well-and a LITTLE heat & time seems to help it get in even more!
In this thread, go to page two, and scroll down until you get to post #26.So where is the best place to hit the rotor so that the rotor will come off but not damage the hub/bearing.
Start hammering at the edges of the rotor hat. Doesn’t need to be super hard, but but hard enough to send shocks and through it. Hit it few times and then rotate 90 degrees. Heat it up with the torch as well. Do this until the hat visibly loosens up.
If it’s really stubborn, soak it in a penetrating oil overnight and try again.
I like the idea, but would be afraid of breaking ears off the knuckle.I haven't seen where it's been suggested to use a nut and bolt from the back side (in the caliper mounting holes) to push the rotor off the hub? Really easy to do - typically just use a 1/2" bolt and nut
I'm sure it can happen, but using a bit of common sense, I'm sure it's a non issue - I've done this many times in these sorts of situationsI like the idea, but would be afraid of breaking ears off the knuckle.
That's a good idea! They do that with hub bearings too! no reason it wouldn't work on a rotor!I haven't seen where it's been suggested to use a nut and bolt from the back side (in the caliper mounting holes) to push the rotor off the hub? Really easy to do - typically just use a 1/2" bolt and nut
Unfortunately it's just as likely to bend or snap the ear off the hub. I don't recommend this method.I haven't seen where it's been suggested to use a nut and bolt from the back side (in the caliper mounting holes) to push the rotor off the hub? Really easy to do - typically just use a 1/2" bolt and nut
Excellent point! After recently bending the ears on a Subaru knuckle-- albeit in my press -- I agree this is a possibility.Unfortunately it's just as likely to bend or snap the ear off the hub. I don't recommend this method.
