I Have owned the Makita 12V version for over 3 years now and enjoy using it. A big plus is it comes with both 1/4 & 3/8" anvils so no need to purchase 2 different ones, I feel 1/2" drive would be about useless in a cordless ratchet.
For small bolts like m6 with a 10mm head I use this, at first I though it was a toy but it has become invaluable, on the lowest setting it is perfect for dash and console work and on high it does anything needing 15ft.b or less.Yes and no I suppose, the speed of the M12 is nice, running out 6MM fender liner bolts is a breeze, behind the dash panel with the right extensions and adapters, etc.
But again, the M12 has a fair amount of torque, it won't strip a M10 bolt, but can really crank them down.
If you know it will fit and already know what configuration you need, it's a time saver if you want to justify a purchase.
But I also agree that a hand ratchet with the right extensions will do the same job, but why do we use these power tools for the most part? To mainly save time and make the job easier when needed...can very well be a preference thing.
Yep I keep an M12 screwdriver on my cart for the same reason. I'll set the clutch really low and run in dash screws without a careFor small bolts like m6 with a 10mm head I use this, at first I though it was a toy but it has become invaluable, on the lowest setting it is perfect for dash and console work and on high it does anything needing 15ft.b or less.
Dewalt also makes a 12V line.
I agree, I have it's older brother...probably gets used the most for most small fasteners.For small bolts like m6 with a 10mm head I use this, at first I though it was a toy but it has become invaluable, on the lowest setting it is perfect for dash and console work and on high it does anything needing 15ft.b or less.
Which again requires another battery. Now I’m not opposed to different batteries if you get a combo for a deal. For most diy use it’s irrelevant. It’s not like somebody is going to rapidly wear down a battery from ratcheting.
DeWalt has a nice cordless screwdriver that is 12v so if you already have one it’s a consideration. That said, I personally prefer the rounded 12V batteries of Bosch and Milwaukee.
I have a number of dewalt 20v items, drills, oscillating tools, inflator, radios… I do like their stuff. I also have Milwaukee m12/m18 because they had a better automotive oriented line…I agree, I have it's older brother...probably gets used the most for most small fasteners.
With DeWalt....IMO,.their 20V lineup is fantastic. However for the smaller stuff...I'm leaning more to Milwaukee. Since it's a different battery anyway with DeWalt, I'm fine with mixing up platforms.
I did look at their 12V ratchet, but was too big for what I needed it for, so I went with the M12.
20V Dewalt and the M12's pair well for me so far, but these Bosch drivers keep kickin so haven't gone with the M12 yet for those.
I like staying in the same battery stable personally, so I’d probably go with Makita if they have the tools you need. I bought a Makita impact with battery and charger many years ago and had good success with it. Makita makes great tools for the most part.As I was doing the timing belt on my car the other weekend, there was a few spots where it was working by complete feel, and thankfully I could get either a ratcheting wrench or a ratchet in there--but it was like, move 3 clicks and reset, take a few minutes to work the bolt in. I watch plenty of videos of these electric low power ratchets, and I have to ask, are they just nice to have and useful in some spots, but not likely as good as I'm hoping?
I have the Makita 18V line of tools, and was thinking of this, with one of my low ampacity batteries (for least size).
I agree and I think this is the next frontier for tools like this, ie trying to get the size down.I have the Milwaukee M12 3/8 ratchet. It works well for many things, but for really tight spaces none of these battery ratchets really do that well since they are bulky and awkward.
Is TTI building their stuff in Taiwan? Pretty sure it's China?
Despite what the CCP will tell you, there is a small (er, HUGE) difference
TTI is based in Hong Kong.Never really looked into the country of manufacture. Wrongly assumed it was Taiwan since TTI is based in Taiwan. Nothing against Taiwan, but I try to avoid made by the CCP whenever possible. It's hard to escape though. My Dewalt impact and drill were both manufactured in the US with 'global materials'.
