- Joined
- Apr 9, 2024
- Messages
- 33
Rig:
1971 Chevy C10
250 I6
3 on the Tree
2wd
~75,000 miles(believed accurate/not rolled over!)
History: Bought new by my paternal grandfather, driven by my parents for a while. Feb of 1987, with 72k indicated, it was given to my aunt on my dad's side. They put ~1,500 miles on it between then and 2003, at which point they parked it in a garage because they simply didnt need it anymore. Jan of 24, they offer it to me as they are selling the property it was stored at, which I happily accepted. March, truck arrives, and within two weeks I have driven it a short distance.
Current status: Running, driveable, still being serviced.
Work performed so far: Oil change with Wix filter using Rotella T4 + ZDDP additive bottle, six new RJ45TS plugs, a new battery, and two front tires.
Planned work: A few more oil changes as the oil I put in it is cleaning so much sludge out of that engine it isnt even funny(as intended), full ignition service, fuel pump replacement, carb overhaul, all fluids changed, possibly a clutch depending on how adjusting it pans out. Oh, and of course a bunch of gaskets, as I'm sure that T4 will.be washing away piles of sludge that is keeping it sealed. Happily, straight sixes are easy to work on.
Oil sample: Oil in engine when the truck was received was sampled and is currently in Blackstone's labs to give me a baseline of internal wear and see what was in oils made decades ago. May switch to a different lab as Blackstone is excruciatingly slow; results still pending nearly two weeks after they began testing.
Planned use of vehicle: Daily driver 20k/yr.
Planned modifications: Air conditioning, FM radio.
Any recommendations for an oil that's as readily available and affordable as T4 but has the necessary zinc for my cam? Planning on going by lab results to determine change interval but I am suspecting ittl end up settling in on 5k miles. Engine is mechanically healthy from the signs I have just listening to it. Starts INSTANTLY, good power when the shot ignition system lets it hit on all six(and even when it doesnt it still pulls well!), good oil pressure. Lifters pumped up within 20-40 seconds of the first start.
I believe the speedo has NOT rolled over because there is so little wear and tear elsewhere in the truck(steering box tight, driveline perfect, no squeaks, rattles, etc) and because it still had G78-15 bias plies tangled around the front wheels with 4-5 32nds tread left. If it had enough miles on it to have rolled the ODO those would have worn out and been replaced YEARS ago, yanno? And the steering would be sloppy, shifting wonky, et al. 98% sure it genuinely only has 75,000 miles on it.
Here's some video of a short drive I did after getting the fuel tank working again!
1971 Chevy C10
250 I6
3 on the Tree
2wd
