I was correcting your math. I used your overall rate and back calculated... Under no conditions would you get 2.4 cents.
A 74% increase that ends up with 9.4 cent power rate starts at 5.4 cents. If you use the overall rate as you mentioned "14.4¢ all told per KWh regular rate is decent if you ask me, but according to that chart it's 74% higher than a few years ago...." the old rate would be 8.3 cents....
I then calculated the 2.4 cents you pulled out of the air to be the higher increase noted. 2.4 cents would not be correct even using just the power rate.
The charts show % increase, which means the percentage is relative to the rates in the past. An easy example is an old rate of 10 cents would be 17 today if the increase was 70%. What it looks like you did was to subtract 74% of todays rate when you back calculated. The right way to calculate would be to take todays rate and divide by 1.74
The law here in TX regarding truth in rates/billing requires the utility to calculate the overall cost per kwh to more accurately compare and understand what the consumer is paying. I didn't check how the story calculated the rates, but the usual seems to be overall inclusive rate, otherwise there are too many apples and oranges.
Originally Posted By: Balrog006
My power cost is 9.4¢ KWh (standard, peak use during summer after a
set amount is 12.7¢) with distribution and fees accounting for another ~5¢. 14.4¢ all told per KWh regular rate is decent if you ask me, but according to that chart it's 74% higher than a few years ago.... Not sure that's entirely accurate, as it would make the power rate at the beginning of the comparison 2.4¢, I was paying power bills back then and it wasn't that inexpensive.
14.4 is 74% higher than 8.3 cents
To go from 2.4 to 14.4 would be 500% increase (12 cent increase divided by original 2.4 = 5)
What are any of the numberes in your post in reference to?
2.4¢ was my calculated, 74% lower rate for power per the chart-its not been this low in my lifetime let alone since I have been paying for it. In essence it didn't exist.
14.4¢ is my combined rate for power AND fees/taxes currently. It doesn't have anything to do with the story in the OP or the chart, they're talking about Power rates, not taxes and fees.
Where did the 8.3 come in? The way your mixing comparisons of power costs, total costs and random numbers I'm not able to make any sense of what you posted. ie, 14.4 compared to 8.3? Or 2.4 compares to 14.4? Those are different things apples to oranges.
