Hermann
Site Donor 2023
MIne is a 3-5 minute coming to life out of the sleep mode. And at that timeframe it is sluggish needing a couple more minutes to run like it should. After that fine and dandy.10-15 minutes.
It should work, yes.Windows Home 64 bit. It came with Windows 8 originally. I don't have a USB thumbdrive with the capacity for Windows 10. Can I use an SD card plugged into a USB reader/adapter? Should work in theory...
My time quoted is from being completely off and not sleeping. Still seems a bit lengthy. The new Lenovo with SSD has spoiled me.MIne is a 3-5 minute coming to life out of the sleep mode. And at that timeframe it is sluggish needing a couple more minutes to run like it should. After that fine and dandy.
It not that I am upset it takes this long. I would like to know what it is regurgitating for that length of time. Also a boot up from being totally off, doesn't seem to take much longer maybe another minute or two.My time quoted is from being completely off and not sleeping. Still seems a bit lengthy. The new Lenovo with SSD has spoiled me.
I agree...it bugs me that I can't find anything wrong or out of the ordinary. Not a show stopper but certainly an inconvenience. After re-reading everything here I feel that a 1TB SSD and a fresh install of windows 10 will bring it back to its speedy prior life.It not that I am upset it takes this long. I would like to know what it is regurgitating for that length of time. Also a boot up from being totally off, doesn't seem to take much longer maybe another minute or two.
Nor do health routines show anything that warrants attention. My laptop is 5 y.o. next month.. I just start mine up first thing after coming downstairs. By the time the coffee is ready, it's ready. I have a Bunn coffee maker.I agree...it bugs me that I can't find anything wrong or out of the ordinary. Not a show stopper but certainly an inconvenience. After re-reading everything here I feel that a 1TB SSD and a fresh install of windows 10 will bring it back to its speedy prior life.
Go buy a couple - they're dirt cheap nowadays. MicroCenter (a chain with locations all around the country) gives away 32gb ones in order to get you in their stores (with an email offer) or buy 'em for $3-4 for 16gb. You might want one or two to copy any data (pictures, documents, etc) before wiping the drive anyway. Amazon, Walmart, etc sell 'em too, of course.I don't have a USB thumbdrive with the capacity for Windows 10.
Also, before you buy anything, now would be a good time to see if you even need a 1TB drive. 500GB (or even 250GB) may be plenty if you're just trying to resurrect this laptop just to squeeze some more use out of it, and it'll save you a few bucks. 500GB seems to be the sweet spot price/space-wise nowadays. $26:After re-reading everything here I feel that a 1TB SSD and a fresh install of windows 10 will bring it back to its speedy prior life.
I have half a dozen but the largest is 32GB, precisely what Win 10 uses. I'll need 64 to have some room.Go buy a couple - they're dirt cheap nowadays. MicroCenter (a chain with locations all around the country) gives away 32gb ones in order to get you in their stores (with an email offer) or buy 'em for $3-4 for 16gb. You might want one or two to copy any data (pictures, documents, etc) before wiping the drive anyway. Amazon, Walmart, etc sell 'em too, of course.
Not so. The Windows 10 installer only needs an 8GB USB drive.I have half a dozen but the largest is 32GB, precisely what Win 10 uses. I'll need 64 to have some room.
That's odd...my Google research showed 32 GB in every instance. If you are correct it really simplifies things.Not so. The Windows 10 installer only needs an 8GB USB drive.
There's probably a M.2 slot and a SATA slot for traditional 2.5" laptop sized drives. I bet that 8GB SSD is used for Intel's "Optane" they had going on during that time but is now largely defunct as SSD prices have dropped.
What I would do is save all the files you want and then replace both with a single SATA SSD like one of the choices above and then have a fresh reinstall of Windows. That'll really liven up the laptop. The only issue I can see coming across that is if the Windows key isn't saved in the computer - then you'd have to find a key somewhere.
"A blank USB flash drive with at least 8GB of space...."That's odd...my Google research showed 32 GB in every instance. If you are correct it really simplifies things.
I don't believe Optane was really used in any kind of consumer or business computer, and really unlikely for anything that old. It was more for server applications. I understand that the hope was that they might eventually make them bigger and possibly substitute for DRAM in some applications.
I remember the first time I'd ever heard of them was when I applied for a job at Intel a few years ago. They weren't calling it Optane back then - I think 3D XPoint where it was a joint project with Micron. It was supposed to be faster than flash-based memories but wasn't as fast as DRAM. But theoretically it wouldn't wear out like NAND flash.
These hybrid systems can be real nightmares to reinstall or clone. But I would think that a SATA SSD could easily substitute for the original HD. Of course that wasn't what they had in mind. The OP's laptop was probably from an era where SSDs were extremely expensive and this was a bridge to make it more affordable.
I think what you're seeing is what Microsoft says is the smallest size hard drive you can install Windows 10 on.That's odd...my Google research showed 32 GB in every instance. If you are correct it really simplifies things.
