Originally Posted By: Donald
Even a tank gas water heater can recover quickly. Its only an electric tank water heater that is slow.
My water heater is a tank with some copper coils and its plumbed as a zone off my oil boiler. Never run out of how water. I think they last forever.
Well they last the life of the boiler which could be anywhere from 40-60 years or more. It's a tankless loop. You can add a hot water storage tank if the tankless doesn't deliver enough hot water. Only issue with it is that it still runs even in the summer.
Normally you need a larger tank for electric vs gas. I forget the ratio but you see 50-80 gallon electric tanks where the gas one would be 40-50 gallons. Plus in this area, electric costs a lot more per btu than gas so gas is the way to go.
