QS Full Synthetic vs. QS Ultimate differences?
Colorado
Are there significant differences between QS Full Synthetic and QS Ultimate protection oils?
I have been a dedicated user of QS full synthetic oil for years now (and QS Ultimate Durability before the name change) in all my Mazdas (8 to date). The full synthetic is getting harder to find either due to popularity ( lower cost) or maybe declining sales at my local Walmarts. I liked the increased levels of moly (which Mazda seems to continue to incorporate in their oils) in the QS full synthetic. Does anyone know if the QS Ultimate Protection has increased moly levels or comparable moly levels to QS full syn? Ultimate Protection is more readily available and might be my future option. Thanks
In a couple VOA samples on each of them contain around 140PPM Moly. Not much different in that regard. The UP is a 20K oil so kind of for extended drain intervals. I use it, but always drain at 5K. The Ultimate protection may have a better base oil (GTL I think, similar to Pennzoil.)
For the couple dollars more -- QSUP which is Quaker States top the line product is well worth it. The QSUP is totally a sleeper oil. Anybody that has not tried it atleast once -- should!!!
It’s too bad they don’t sell it in Canada, I would recommend it for my friends up here. I ran it in my Civic just before my three runs with VRP.
Isn't QSUP sold only at Walmart? My guess is it has the same formula as QSFS but uses GTL instead of 'plain' Group III base oil.
My feeling is with the base stock interchange allowance, you never know what the basestock blend truly is batch to batch.
My former favourite QSFS 10W-30 shows a pour point of -54 deg C (ASTM D97) . You are not getting that with non GTL grp III
A jug I purchased a year later and installed did not perform magic like the previous one.
What is a boy supposed to do?
Quaker State Ultimate is the only oil I will use, and I put it in everything. Highly recommend to my friends, family and co-workers as well. You just can't beat the green bottle for value and performance! :p
I guess Valvoline bought the company you fraud...
Somewhere I saw where QS said QS Ultimate Durability uses a GTL base oil I think it was on QS website.
I've only seen that said at BITOG, but I've never seen any supporting evidence. I haven't seen it stated on QS website or data sheet, but maybe I didn't read carefully enough, or maybe they used language I didn't understand.
I'd like it to be true because QSUPFS is affordable and easy to obtain at Walmart.
QS, Pennzoil, Shell are under the same parent company
Yes, but they're not the same oils based on data sheets, VOAs, and UOAs. However, they probably share some technology/attributes.
I prefer QS & Shell oils over Pennzoil because QS & Shell synthetic oils (for whatever reason) typically have higher KV100 cSt viscosity for a given grade than Pennzoil synthetic oils. Also QS has better prices than Pennzoil. In some cases Shell also has better prices.
I prefer whatever that mentioned made by Gas to Oil GTL process. It is just clearly better than plain heavily hydrocracked mineral oil (HC synthetic = group III).
GTL oil has all the benefit of group III, more stable than group III, much less price than group IV PAO. I think QS, Shell, Pennzoil sold the GTL under the top of the line Platinum Ultra.
I downloaded and checked data sheets in recent past, and looked at VOAs & UOAs posted at BITOG.
1) Pennzoil Ultra Platinum has lower than average viscosity per grade.
2) Quaker State Full Syn has slightly higher than average viscosity per grade.👍
3) Quaker State High Mileage Full Syn has slightly higher than average viscosity per grade.👍
3) Quaker State Ultimate Protection Full Syn has much higher than average viscosity per grade.👍👍
4) QS oils cost much less than PUP. 👍
There's also differences in additives. They're not the same oils. All 3 are available at my local Walmart. All my local autostores all carry PUP. NAPA sells QS. Oreilly does not sell QS.
If QSUPFS really is GTL or part GTL that's another feather in its cap.
Yes, GTL oil usually has significantly less additives package needed to satisfy the requirements for VW 508 509, Dexos D, etc. compared to HC or PAO+Ester oil. It relies on the robust characteristics of the base GTL oil. Less gor more concept is very intriguing
Agreed. Do you think Quaker State Ultimate Protection Full Syn is a GTL oil or part GTL?
