Originally Posted By: Dyusik
Originally Posted By: jk_636
Originally Posted By: DuckRyder
Very impressive a $7.00 oil filter went 3000 miles...
It could have gone longer. I regularly take them to 5k miles. (I dont do any OCI longer than 7k. I just dont believe in extended intervals.) I pulled this one and changed the oil because I had ran it pretty hard a couple times off road, and had some Mobil 1 that was burning a hole in my stash
Considering MANN is a puro, you don't have anything to worry about (given no tear's happen), cause I took one to 17k+ on a Bimmer once. I have a P1 on the jeep, and plan to take it 3-4yrs ( about 5k, dirty engine, massive blow by, and wheeler), and on my bike for 2yrs, (3-4k because of transmission+engine). People don't give enough credit to filters, given a clean engine and no defects, a filter should last 20k easily. Just put my old wix back in for another run one Lexus cause it looked like yours after 5k.
I dont know about running a filter that long, but in theory I agree with you. With a clean engine and ideal driving conditions a filter should hold up just fine.
See above filter.
-New production
-severe service
-no failure.
Granted, 10-16-2014 is "newer", but not as new as a few recent posted failures.
Is there a reason you chose the full synthetic Purolator - even though you don't believe is "extended OCIs"? My guess is because no reports of failed full synthetic Purolators so you don't want to risk a torn filter on your vehicles. Why not run a Classic or PureOne again?
I use Purolator Synthetics and Pureones. I go back and forth between the two, but up until recently I exclusively used Pureones. It even says so in my signature. I dont use classics. Not because Im worried about them failing, but because I like the higher efficiency rating of the other two. You dont have to have ridiculous OCIs to appreciate a good synthetic filter. I started using the Purolator Synthetic when I recently switched from Mobil 5000 to Mobil 1.
I actually replaced it with a Fram Ultra this go around. NOT BECAUSE IM WORRIED ABOUT PUROLATORS TEARING, but because I bought one when they had the rebate and I want to see how it stacks up against the Puro synthetic.
But rest assured, I will be returning to Pureones and Synthetics after this 5k mile OCI.
See above filter.
-New production
-severe service
-no failure.
