Originally Posted By: HangFire
3. Restriction Test - A low pressure flow of 3GPM of 30W oil at 180F is passed through the filter and the deltaP is measured.
My filter passed the first two tests, the Restriction Test was then discussed. A typical value is 8PSI but my filter was highly restricted at 23PSI.
Since this is higher than the built-in bypass valve, he suggested that the filter was probably running in bypass mode for some period of time. (I forgot to ask if it was torn because I was trying to write down all the data, but the question may have been pointless considering the impulse test.)
The filter was then cut and a high level of metallic contamination was found in the media, but no sludge. They no longer have the filter (their fault, for letting this drag on so long) but offered to test the torn filter if I can find it to send in.
Wow, a delta-p of 23 PSI with only 3 GPM of 30W oil at 180 deg F is pretty bad. I'm assuming the media was basically totally clogged and if so that means the bypass valve isn't capable of flowing 3 GPM without creating lots of delta-p. That's not a good thing really. Any more info from Purolator on why they think that filter has such high delta-p?
Here's some data Purolator provided a while back on another PureOne, and the delta-p was really low.
PureOne Flow vs Delta-P Test Data
The Director of Engineering pointed out a few facts about the PureOne. One, the PureOne is a 99% at 20 microns filter. I pointed out that this published data is NOT clear on their marketing information and the general opinion on the boards is that the Ultra is better and the PureOne is something less than 99%.
I really don't recall anyone saying that PureOnes have less than 99.9% @ 20 microns efficiency, EXCEPT for the few that are rated at 99.9% @ 40 microns.
So I asked, what about the Classic, since that is where the majority of media failures have been reported? After some back and forth, it was clear that Marketing was aware of the Classic problem and the tear spreadsheet, but Engineering was not. The spreadsheet is being forwarded to Engineering as I write.
Actaully, the tear record speardsheet has MORE PureOnes failing than Classics. 28 PureOnes vs 17 Classics.
Tear Sreadsheet
Tear Sreadsheet
