Originally Posted By: Hessam
is that 3rd pic from the top before you cut the filter open? if so, looks like the ADBV was installed backwards. The side of the Anti Drainback Valve facing the oil hole inlets should be the smooth side to form a complete seal. It looks like the side with the raised ridges is facing the oil inlets, which would make is impossible to form a complete seal.
If you look at the last photo, it looks like the ADBV was installed correctly based on the concave shape, and also the center hole area where it fits around the end cap on the filter element.
ZeeOSix, I agree the last pic is how it should be installed, but the 3rd pic from the top, as well as the 5th pic from the top show the exact opposite of that. If the OP could confirm how the ADBV was installed when he opened the filter, it would help. I have never seen those raised ridges showing through the oil inlet holes (as in the 3rd pic from the top).
The 3rd photo from the top looks like it was taken before cutting the filter. Based on the ridges on the ADBV, you can tell how it was installed before the filter was cut open. Looks to be installed correctly to me.
