I've had great luck with Purolators, 14476 or the longer 14477. The 14477 might be iffy since on your Prizm, the filter is under the engine in a vertical position. IMO, having the filter in this position with the inlet/outlet facing up negates some of the value of a silicon antidrainback valve.
In all honesty, I really like the Champion labs based filters in this application because of the way the bypass valve is. Supertech 4967 is a great filter and super cheap.
But like Gary Allan indicated, if you want to go long on oil changes, I'd go with a Mobil 1 EP filter, also made by Champ.
