6-month OCI (from May 16 to November 12, 2008).
Toyota OEM air and oil filters (Denso 90915-YZZF1).
19,620 total car miles.
This was my second consecutive fill with PP 5w-30 (API SM & GF-4). Had previously used Mobil 1 and Valvoline Conventional.
Always gentle driving on roads in Columbia, Missouri and St. Louis.
Special Notes: The first 3,200 miles of this approximate 5,000-mile OCI was exclusive city driving with most trips averaging between 15 miles and 30 miles (all city, again). The next 1,700 miles of this OCI was a 50/50 mix of city and highway.
On the actual day of the oil change, just before changing the oil, I drove the car about 30 miles on the highway, then let it idle 15 minutes while I brought out the ramps and other equipment.
Although my manual calls for 4 quarts of oil when changing the oil filter, I always put in 4.25 quarts.
This is Toyota's 2.4L 2AZ-FE engine, an inline 4 cylinder.
Blackstone-Labs results:
Miles on oil: 4,920
Miles on engine: 19,610
Sample date: 11/12/2008 ; Report date: 11/24/2008
Makeup oil added: 0
[First number = my sample's results] / [Second number = Universal Averages for this engine]
Aluminum 3 , 3
Chromium 0 , 0
Iron 7 , 10
Copper 1 , 2
Lead 3 , 2
Tin 0 , 1
Molybdenum 53 , 90
Nickel 0 , 0
Manganese 0 , 0
Silver 0 , 0
Titanium 0 , 0
Potassium 2 , 1
Boron 28 , 39
Silicon 17 , 17
Sodium 4 , 14
Calcium 2795 , 2347
Magnesium 15 , 121
Phosphorous 714 , 719
Zinc 860 , 853
Barium 1 , 0
MY RESULTS // VALUES SHOULD BE
SUS Viscosity @ 210* F 59.3 // 56 - 63
cSt Viscosity @ 100* C 10.03 // 9.1 - 11.3
Flashpoint in * F 400 // > 365
Fuel % < 0.5 // < 2.0
Antifreeze % 0.0 // 0.0
Water % 0.0 // < 0.1
Insolubles % 0.2 // < 0.6
TBN 4.7
TAN 0.9
Built_Well's Note: The TAN and the TBN readings cost an extra $10 each, and you gotta request them at Blackstone if you want them. I forgot to request the TAN, but I emailed them a day after receiving my results, and they pulled my oil sample and ran the TAN. I was happy that they didn't immediately throw away my oil sample after running the standard tests the day before. I don't know how long they keep the oil samples, though.
Anyway, I wanted a TAN (acid) reading just for fun to compare it to RLI's Bio-Syn reading when I send the Bio-Syn 0w-30 to Blackstone in 6 months. The results above for the used Pennzoil Platinum 5w-30 oil happened during moderate temperatures and weather from May to November (mostly Summer and Fall). I think it'll be interesting to compare the nice weather PP results to the harsh weather Bio-Syn results (Winter).
Miles on oil: 4,920
Makeup oil added: 0
Aluminum 3 , 3
Chromium 0 , 0
Iron 7 , 10
Copper 1 , 2
Lead 3 , 2
Tin 0 , 1
Molybdenum 53 , 90
Nickel 0 , 0
Manganese 0 , 0
Silver 0 , 0
Titanium 0 , 0
Potassium 2 , 1
Boron 28 , 39
Silicon 17 , 17
Sodium 4 , 14
Calcium 2795 , 2347
Magnesium 15 , 121
Zinc 860 , 853
Barium 1 , 0
TBN 4.7
TAN 0.9
