Post Your Latest Coolant Change.
Here is the clamp expander which I used from above the radiator to the bottom hose. The bottom hose connection is shown inside the red circle. There is not much room to get pliers or a pair of clamp piers down in there.
Since there is no radiator cap, the engine is filled through the coolant jug.
View attachment 210121View attachment 210122View attachment 210123
I found the drain plug on the 2017 Tahoe going in from the fender - not fun at all - but got a gallon of AC Delco Dexcool concentrate in …
Going to leave that alone for a year - try it again by removing the air box …
Here is the starting point reading, the reading after diluting it with distilled water, and the reading after draining part of the diluted mixture and adding concentrated anti-freeze. Also are the shot of the Dexcool jug, the drained fluid and the final view of the jug. Dexcool is orange but looks red through the translucent plastic of the coolant jug. Inside black drain pans it looks brown, but nope, it’s not rust. Enjoy.
2010 Chrysler Sebring
2.4 4 cylinder
Replaced water pump and coolant outlet manifold
Dump and fill, no flushing
Out: unknown green coolant
In: Prime Guard conventional green full strength/distilled water mixed 50/50
I paid a local mechanic to replace the coolant in my inherited 98 Chevy. I just couldn’t figure out how to get my hand on the petcock and I was afraid I was going to damage the transmission cooler line when trying to disconnect the lower hose.
98 Chevy K1500 5.7L Vortec
52K miles
Out: 26 year old factory fill Dexcool
In: Prestone orange + distilled water
Should be good for another 26 years, right? LOL
2005 Ford Taurus with 120,000 miles
Out: Prestone 5 year
In: One gallon of Prestone 10 year and a 1/2 gallon of Prestone 5 year.
I had to lower the front “valence”. There is no radiator cap as it loads through the pressurized coolant jug.
There is a plastic drain nut that turns with a large allen wrench. It has an O ring and works well.
Two gallons come out of the rad and jug, and one gallon is left behind in the block. I drained the two gallons, closed the drain and filled with two gallons of distilled water. I took the car for a 15 minute drive, then brought it back.I made sure there was hot air coming out the heater and that the rad was hot.
After cooling I drained another two gallons. The diluted coolant freeze point was 0 F indicating it was diluted down to 33% from the original -45 freezing temp in the rad. I then added 1-1/2 gallons of concentrated coolant and 1/2 gallon of distilled water. Took it for a drive and I’ll check the concentration when it cools. The coolant looks green in the drain pan but is actually yellow/green.
Both the new 10 year and 5 year have a yellow look. The coolant in the tester is the coolant that was in the rad before I first drained it.
Here is a shot of the diluted coolant I drained after circulation with the two gallons of distilled water. Also are two shots of the concentrated 10 year (first) and 5 year (second) concentrated coolants going in. All done. Final shot is the jug. I had to dispose of 4 gallons of used coolant that virtually looked new hopefully meaning my original rad and heater core are in good shape.
And here is the final shot after it mixed and cooled down. It’s good for below -45 F. ( just in case I drive to Edmonton.) Notice the yellow green colour of the Prestone coolant.
1979 Chevrolet K10
350 small block V8
Replaced radiator hoses, thermostat, flushed block, heater core and radiator
Out: unknown brownish coolant
1989 Ford F-150
4.9 inline six
Replaced radiator, radiator hoses, thermostat, flushed block and heater core
Out: mostly water from the looks of it
In: Prime Guard conventional green full strength, distilled water mixed 50/50
2004 Ford Ranger
3.0 V6
Replaced radiator, radiator hoses, thermostat, heater control valve, flushed block and heater core
In: Prestone All Makes All Models premix
2010 Chev Silverado 4.8 liter V-8 189,000 miles
Out: 5 year old Dexcool in good shape.
In: Dexcool
This year of Silverado does not have a drain valve. Used a remote clamp tool to loosen the clamp and pulled off the hose to drain into a large tub.
I drained out about 1-1/2 gallons. Added 1-1/2 gallons of distilled water, put the hose back on, took it for a drive until it warmed up and then 15 minutes of driving. I let it cool and drained that. I then added 1-1/2 gallons of 100% concentrated Dexcool.
Here's what the coolant in post 656 looked like after draining the coolant that was mixed with 1-1/2 liters of distilled water. I then put in 1-1/2 liters of concentrated Dexcool to fill the rad and get my freezing point down past -45 C.
