Originally Posted By: EMT_760
Originally Posted By: The Critic
This has been a common “problem” with some of the newer Toyota engines - 3.5, the new 1.8, etc. The published oil capacity is usually too much. I have found that 1/4 qt less than the published amount is usually perfect. Keep in mind that the oil level will rise a bit once the engine is warm, so your goal is to have the oil level read max (and no higher) when checked on a hot engine.
yes this is the 3.5. So do you think I should drain a bit? I can't imagine it being that much. I put in 6.2 quarts. Maybe there was some residual hiding in the transmission cooler line?
Having that much in extra should not cause any foaming or any harm correct?
Yes some "residual" oil remains so if you keep adding 6.2 quarts with each oil change and you are only drsining 6.0 quarts because 0.2 remains as "residual" then you can see you are creating an overfill condition more and more.
You can measure exactly how much oil you remove and then add an equal amount at similar temperature or use the more common practice...Ause the dipstick since it is designed to prevent this overfill from occuring.
Stay within the hatchmarks of the dipstock and there is no need to fill to the top MAX mark. The engine is designed to function anywhere between MIN and MAX. There is no wrong answer if you remain between the two.
Is it worth drainng some out now? Probably not.
Is it a good practice to always run above MAX? Probably not.
