5K run with 4 quarts of Pennzoil High Mileage 5W30 (API SN) and one quart of Pennzoil Platinum 5W30 (API SN).
Vehicle is 2004 Lexus RX330 (3.3L V6) with just over 155K.
History of oil changes:
-Oil changes every 5K
-Oil filter every other change
---Mobil 1, Fram Xtended Guard, Pure One, Bosch Distance Plus
---current filter is Distance Plus
-OEM air filter (will be changed soon)
Comments from Blackstone were overall positive.
CURTIS: The string of perfect reports continues with this most recent sample from your Lexus. Wear
numbers are at some of the lowest levels we've seen, and considering that this engine has a long history of
nice, low wear, that's really saying something. The oil mix you're using certainly seems to be working, so we
wouldn't change a thing if we were you. There were no signs of contaminants and all the additives and
physical properties were consistent with previous samples we've seen. The TBN was good at 2.3, so there
was still active additive left. Nice report!
I welcome any feedback.
Code:
Miles on oil: 5,180 5,320 4,050 6,640 8,611
Miles on unit: 155,130 110,400 87,750 71,840 55,520
Date: 01/01/12 06/20/09 12/15/07 12/30/06 09/09/06
Make up oil: 0 quarts 0 quarts 0 quarts 0 quarts 0 quarts
Oil Pennz mix PP PP M1 M1
Aluminum 2 3 2 3 4
Chromium 0 0 0 0 0
Iron 5 6 7 10 7
Copper 1 1 1 0 0
Lead 1 0 0 0 0
Tin 0 2 0 0 0
Molybdenum 236 44 146 73 65
Nickel 0 0 0 0 0
Manganese 0 0 0 0 0
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium 4 2 2 2 3
Boron 37 24 21 71 108
Silicon 15 13 10 14 12
Sodium 6 3 3 13 10
Calcium 2572 2695 2669 2185 2455
Magnesium 10 10 10 12 13
Phosphorous 852 562 742 596 692
Zinc 967 645 791 697 803
Barium 0 0 0 0 0
SUS Viscosity@210 56.2 57.0 63.0 59.2 61.7
cSt Viscosity@100 9.12 9.35 11.06 9.98 10.69
Flaspoint in F 385 390 405 380 375
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.2 0.3 0.3 0.3
TBN 2.3 n/a n/a 2.7 2.0
Code:
Aluminum 2 3 2 3 4
Chromium 0 0 0 0 0
Iron 5 6 7 10 7
Copper 1 1 1 0 0
Lead 1 0 0 0 0
Tin 0 2 0 0 0
Nickel 0 0 0 0 0
Manganese 0 0 0 0 0
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium 4 2 2 2 3
Sodium 6 3 3 13 10
Barium 0 0 0 0 0
Fuel %
