Originally Posted By: skyship
Originally Posted By: gathermewool
So, you've run the engine since the oil change, right? You could have some fuel dilution, which would raise level.
UMM! Only if he put the fuel nozzle in the oil cap!
Some engines have at least 10% residual oil after draining even when hot, so if a car should hold 5 ltrs, just add 4 ltrs and check the dipstick, BUT don't add more than a half litre until the car is run again etc.
The amount he's seeing on the dipstick can very easily be attributed to a few percent fuel dilution. OP, unless your UOA is showing zero fuel dilution, it may be that the analysis used is simply under-reporting the amount. 3% fuel dilution into 4.3 quarts of oil is 0.13 quarts or 4 oz, which may or may not be noticed on the dipstick.
Also the conditions you drain the oil at for a UOA sample may not be the same as how the car as been operated over the past couple of days since your oil change. If your driving habits have changed, then fuel dilution could be the reason.
The oil you've used for the past two changes - were they purchased at the same time? It could be that the jugs were over-filled or the increments improperly marked.
Finally, 0.3 quarts is NOT a big deal. My STI usually shows as full on the dipstick after 4.8 quarts; 4 quarts will get me to the Add mark. I don't think twice about dumping leaving the bottle in the fill port until it has dripped nearly entirely empty. IMO, there is no issues with being slightly over-full, and, in certain applications, is beneficial.
In summary, add as much as is called for and don't worry about being over-full by such a measly amount. It really doesn't matter. If it does bother you, then dump in 4 quarts and forget about it.
