Originally Posted by gathermewool
Originally Posted by BMWTurboDzl
Interesting fact. "Dirty" condenser coils have essentially no impact on the efficiency of refrigeration systems.
http://theconversation.com/skip-thi...probably-wont-make-it-work-better-113158
Note: Yes this link is about coils on a HVAC system, but these coils are infinitely more dirty than anything you'll find on the coils of a refrigerator.
A LOT of holes in this article:
1. Dirt vs capacity: they're measuring in grams of dirt per ft^2
-----Why was there a substantial increase when 6 grams of dirt/ft^2 was removed, but no benefit to cleaning 8 grams/ft^2 of dirt?
-----Guess: dirt is not dirt. Tightly-adherent dirt that accumulates and has good insulation properties isn't the same as a 8g coating of pollent, I would guess
2. Turbulence: To say that dirt likely contributes to turbulence makes me lose ALL respect for this article. If dirt is covering the coils or fins, then cooling capacity is lost - fact! In an air heat-exchanger, with tightly-packed coils and fins, what kind of flow does the author think is present?
Explanation (my opinion): A/C systems are designed to cool/heat to a design specs with an assumed dirt load. I would assume the cooling capacity, motor cycles and refrigerant pressures are designed with a certain dirt load as a part of the design assumptions.
I'm sure the designers also realize that most of the jamokes they sell these things to won't do any maintenance on the condenser coils and have designed for that.
Finally, to say that a dirty A/C heat exhanger will operate more efficiently is stupid.
Ya I have no idea but here's a link to the study. I thought the article was itself interesting.
ASHRAE
