I was on another board and there is a guy who has been having a lot of troubles with his tranny since he did a complete fluid change over to Mobil 1 Synthetic ATF. He kept getting a high AT temp light and then he would remove the pan and find a bunch of gunk in it. He cleaned the pan about three times in one year. Finally he sent in a sample for analysis and got this. The mfg recommeded fluid for a '90 Mitsu is "Dexron" or equivalent. Back then they were not even up to Dexron II let alone Dexron III.
I am worried because I just put Mobil 1 ATF in my '95 Montero where the manual says "Dexron II" or equiv.quote:
I heard back from Blackstone today on my ATF analysis. Apparently the news was so urgent that they even gave me a courtesy phone call! On the phone, they all but said that the Mobil 1 ATF is what's causing the problem...
(from printed analysis)
Quote:
DOUG: We didn't find any water in this sample, though we did find high insolubles and metals. The insolubles were gray, indicating they contained metals and were not just oxidation byproducts (which are black). Excessive heat can also cause high insolubles. The iron and copper probably show wear at the clutch plating, so you might want to start there as you figure out what's wrong with your transmission. You might also want to double check that Mobil 1 ATF is okay for use in this transmission. Not all oils are okay in all transmissions. We don't know about this particular one.
Basically, copper was shown at twice the wear it should be (133ppm) and iron was more than 3x what it should be (291ppm) and after only a few thousand miles!
I brought some Diamond brand ATF with me on my way down to work this time, but I need a couple more quarts and a priest to completely exorcise the old fluid.
My plan is to home flush the A/T through the cooler line, drop and clean the pan, replace the filter, and replace all the ATF. Hopefully that will give better results. I'll follow it up in a few months with another analysis to confirm, but as a head start to those using Mobil 1 ATF without any kind of additive, DO NOT USE IT on your Montero/Raider A/T!
Hopefully, after my 20mo Mobil 1 ATF experiment, my A/T isn't too far gone that I can't save it with a simple fluid change. Glad I'm dilligent about maintenance and performance issues. I also plan on installing a larger A/T cooler at some time in the near future (despite the outcome of this experiment). Also want to add a temp sensor in the A/T oil pan just to monitor future occurances.
This makes me want to send in a sample of my rr diff gear oil. I've been finding a lot more metal shavings on the drain plug since switching to Mobil 1.
The good news is that there was no water found in the system, which means my gearbox breather system is performing well and that my A/T temp sensor is performing as it should. - Hey, you've got to find the positive in everything!
A/T info:
Mitsubishi KM148 (A44D)
LOST ARK (IL)
'89 Raider 3.0L V6 (6G72) w/ KM148 (A44D) A/T
"The Millennium Falcon of automobiles"
