Originally Posted By: ZeeOSix
Originally Posted By: Shannow
But you can convince me, with data...if you've got it.
I'll say the same thing to you. Based on your belief, what would you say is the total change in flow volume of an oil squinter over the entire PRM range of an engine from idle to redline? Is it 1%, 15%, 40% ... ?
I told you, squirter oil flow is based on pressure applied to it, not RPM...asking for an answer to a nonsensical question ?
But here's how much oil a bearing draws...
Pick an L/D ratio (that's length to diameter, make it 1/4 because that's close to engine bearings....make viscosity, make clearance (c), Radius (r), and load (P) and viscosity (u) constant, and change RPM...upwards, and you can see that the normalised flow drops with RPM...
The bearings require less oil, draw less oil from the galleries to make up for side leakage...in bug turbine bearings, they will draw a couple of psi vacuum to attain that make-up flow.
So bearings, all things being equal draw off less normalised flow as RPM increases.
PD pumps provide a linear volume RPM relationship.
So providing a linear flow availability (PD pump) to a reduced requirement for make-up (the bearings) creates more backpressure with increasing RPM, which you read as oil pressure...
Simple, isn't it ?
As can be (very) simply deduced, looking at the slopes of the curves, a cam turning at half speed has a different change in flow characteristic as the mains.
The squirters, obeying regular laws of physics, flow more with this increasing pressure, and the ratio of squirter flow to bearing flow therefore increases...the percentages change, and are not fixed.
Again, asking a nonsensical question (% change in squirter flow versus RPM) in and of itself clearly identifies that you really haven't had the opportunity to grasp fluid dynamics...
Is your position based on science or belief ?
By asking the proverbial nonsensical question, I'd posit that you lean towards the latter.
(and science has proven that when your beliefs stop working, the centres in your brain that respond to pain light up, and you reject it).
