- Joined
- Jul 2, 2007
- Messages
- 5,294
Originally Posted By: ARCOgraphite
Originally Posted By: BJD78
I have a 2010 Forester 2.5 with 4EAT. The OM clearly states that 5w30 is the preferred oil.
Do you know what "preferred oil" statement REALLY means?
The Ej can run on a 40 or 50 in the heat though it is not usually needed.
Per Manual. IIRC the capacity is 4.2 LITRES which is a bit over 4.5 QTS.
Topping with a 10w30 FLEET oil ( Like Rotella Tripe protect DINO 10w30 or a 10w40 Mobil Clean is good.
This engine has a TSB on oil burning due to a improperly machined valve guide pilot holes.
The CNC drilled a hole and then drilled a hole and reamed it just less than 1 cm away making a "B" shaped hole.
Whoops .. Good QC at the engine plant
Gotta ship $$ dollars $$ or the mafg manager gets no bonus - or worse!
My wife had one of those and the thing ate oil and smoked out the tail pipes.
LoneRanger has a good one. This is a GOOD car and engine. Better than the newer ones.
Do you have the TSB number because I've never seen or heard of that defect, the TSB, or an issue with 09's and 10's consuming oil. I can't find anything about it in a google search, it only pulls up the 2011- 2015 model years for oil consumption.
