Originally Posted By: CR94
Originally Posted By: KrisZ
All engines have to consume oil, all of them, but the normal amount, on a healthy engine with properly broken in and not stuck piston rings, will not be noticeable on the dipstick or the change in the level should be minimal.
And low tension piston rings are nothing new, it's just something people like to repeat to convince themselves and others that it is normal. You repeat it enough times and it becomes the truth.
I agree, and therefore have doubts about some of the popular theories above.
Advertising and press-release fluff in 1980 for my '81 Mazda bragged about its low-tension rings (among other fuel-saving then-new features). My current car, the Prius, also claims low-tension rings, uses 0W-20 (sometimes 5W-20), yet so far consumes far less oil than any other engine with which I've been acquainted.
How is that possible if low-tension rings and "watery" oil necessarily cause high oil consumption?
Nobody has said (obviously that it does so in all occasions...ever seen one of these ?
The OEMs are defining "normal"...note, it's THEIR definition at the tail end of the curve.
