Originally Posted by 69Torino
Coworker has a catch can on his 2018 F-150 5.0. It works. He empties it about every 1k miles, out of boredom. It usually has 3 or 4 ounces in it. Oil not it the intake is a good thing. I have taken intake manifolds off lots of GDI Kia engines and dumped 12 ounces of oil down the front of my pants as soon as it clears the core support.
FWIW: Hence, why on my turbo Optima I have one on the PCV side and one on the crankcase intake side (which reverses flow during significant boost). These are the Saikou Michi brand made for my car. I have ball valve drains with hoses that drop past my belly pans on both for super easy draining. I normally get ~2 oz of oil/water mix between 4K mile OCI (a bit more in the winter and it is more "watery"). I've NEVER gotten any on the crankcase intake side and deem this just not needed but it is installed and I'm leaving it alone.
When I replaced my engine at 77K miles (long-block under warranty) and took a good look at the intake valves, they had deposits but it was not super bad (I've seen much worse on the interwebs) but bad enough to need walnut blasting at some point IMHO, so I can only hazard a guess that this has help slow the accumulation but will not totally prevent it - at least on my car with my mods and the way I drive it (DD, 20 miles to work). I like the OCCs and will continue to run them and started life with my new engine with them installed from the get/go. The picture below was the worst of the four (Cyl#2):
