My Nissan Sentra 2005 is a bit above 83000 mi and I bought it used on CL at 75k mi. I don't have any maintenance records on the car but I have been doing oil changes regularly.
The automatic transmission fluid is dark pink but not black:
I took two pictures, both with the ATF on the left and Engine oil on the right
One is with flash and one without.
http://imgur.com/a/KGeFb
The ATF looks dull pinkish to me. So not dark. Which I think is good news?
Hoping not to stretch my luck that the ATF is still not dark, I decided to change the ATF this month, but cannot figure out what to get.
The service manual calls for Nissan Matic D, and the dealer is willing to sell it to me for $15/qt with a 30 day lead time as they don't stock it locally.
Reading the FSM from 2005 closely and reading on forums, Nissan Matic D can be replaced by a Dextron III/Mercon but there is significant controversy and ambiguity as to which equivalent is best suited:
It looks like most suggest that most synthetics are a good alternative, including Valvoline Maxlife ATF, Castrol Multi-import ATF and Amsoil ATF, to name a few.
Also, since the FSM was written in 2005, the Dextron III has been disenfranchised and made "more generic" than before (would love to stand corrected!).
So my questions are these:
1. Is anyone on this forum who actually used any of these alternatives in their 2005 Nissan Sentra instead of the OEM Nissan Matic D?
2. What was your experience and will/did you change your choice?
3. Have you considered using this to replace the PSF of the Nissan Sentra? (or perhaps this should be a separate question?)
