Originally Posted by ZeeOSix
….I have the same Summit filter cutter and ran into the same thing you did Sayjac. I was thinking of unbolting the beam from the end piece and hogging out some metal between the wheels with a die-grinder to make clearance for the smaller filters. Probably would take less than what I show below. Hope you don't mind me showing how with a snip-it of your photo.
No problem at all. Your fix could get it done. There's one member who replaced the wheels on the cross bar with wider diameter wheels. They were white, some kind of composite material. I found where he posted pic, however they're no longer viewable. Seemed to address the issue.
