Originally Posted By: Pablo
Mostly ignored in these written gymnastics is the cleanliness of the engine.
I'm not ignoring it; I'm intentionally dismissing it.
What often goes unchallenged is marketing hype that is unsubstantiated with real, documented proof.
In a normal OCI, I don't think there is much difference, if any, in "cleanliness" between a robust dino oil and a good synthetic. The "new" (now several years old) CJ-4 lubes have a very healthy detergent/dispersent package in them due to the EGR use, and the next generation of lubes will even be more so. I doubt there is much if any difference in "cleaning" ability between any dino and any syn HDEO, in a normal OCI.
We could look at PDS/VOA data and imply something, but there really is no quantifiable data to say how well a product would "clean" from a results driven perspective.
First, we'd have to define what "clean" means.
Then we'd have to find a way to measure "clean".
Only then could we study the true effects of a product's ability to "clean".
So, while I cannot prove that dinos clean as well as syns in normal applications, you could also not prove they do not. I see this as marketing hype.
Further, I've used this analogy several times, but it's obvious it's time to bring it back out again ...
I'm going to presume we are starting with a healthy, decent engine, and not one that is absued/neglected.
"Cleaning" can only occur when there is dirt (my generic term here for this example). If no dirt exists, no cleaning can occur. And when dirt does exist, there must be some level of dirt contribution rate, to the environment. It's not like dirt just suddenly comes from the sky and is trashed immediately; it accumulates over time. Therefore, there is a "contamination rate" that exists for the environment.
Example:
An elderly couple live in a decent home. They have a maid come and "clean dirt" once a week. The contamination rate they create is satifactorily removed by one maid, in one week intervals. The dirt accumlates during the week (not unlike soot production in an engine) and the maid comes once a week to clean (not unlike an OCI).
As long as the contamination rate is reasonably controlled, then the "need" for "more" cleaning is a waste. You can send in more maids, but they cannot "clean" any faster, or any more quantity, than the couple of old folks creates in their daily activity. I don't care how many maids you send in, it does not make the old folks create "more" dirty dishes, laundry or dust. The only way to alter the "need" for cleaning is to send in the grandchildren. That is altering the contamination rate. Only then would you "need" more maids, more often. Get it?
Same goes for a decent HDEO product. You can heavily dose in more add-pack, but that does NOT change the rate of soot production or insolubles made. That heavily dosed add-pack cannot "clean" any faster than what is produced.
In short, cleaning agents can only remove what exists; they don't produce "dirt", they only remove what is presented to them. Therefore, they don't affect the contamination rate. As long as the chosen product can keep up, there is no real benefit to "more" cleaning agents.
So if the dino oil is fully capable of cleaning at the "normal contamination rate" , then any "more" than that capability level is unused capacity. Period.
Conceptually, this is not unlike the topic of filtration capacity. NOT efficiency, but capacity. You can find filters with more holding capacity, but that does NOT make they clean "better". They will however, given a reasonably consistent contamination rate, clean for a longer period of time, because they can hold more before becoming overwhelmed (saturated).
Therefore, what a high-end oil (with a heavy add-pack) can do is last LONGER in service. Any lube (does not matter which base stock) that has "more" cleaning agents, can last for a longer OCI before it becomes overwhelmed (saturated).
But that goes right back into everything else I've ever said about dinos and syns. Syns are not "better"; they last LONGER in service. And if you don't extend the OCI to a point where the dino oil is compromised, then there is no true advantage to the syn. Any product (oil, toothpaste, orange juice, etc) can only have an advantage or benefit over another product, if that competing product is overwhelmed in some defined, measurable criteria or characteristic.
How can any lube (regardless of base stock) create a "cleaner" engine, when they cannot affect the contamination rate???
Engine cleanliness is a function of the OCI. If your engine is "dirty", it's because you extended the OCI too far, relative to the lube used.
Even a synthetic, even the "best" synthetic, would eventually leave an engine dirty, if used past a reasonable limit.
BTW #1: just so we're clear here, I'm not picking on Amsoil. I'm being generic to syns.
BTW #2: heavily-dosed detergent packages can have an adverse affect on wear rates. In SAE study 2007-01-4133 there is evidence that shows the add-packs can actually inhibit or scrub away the beneficial tribochemical anti-wear layer that develops on the part surfaces as the OCI ages the lube. And believe it or not, oxidation is key to that anti-wear layer developing. IOW - some amount of lube oxidation is a GOOD thing. Obviously, too much oxidation is bad, but some amount is truly beneficial. Allow me to quote a very short concept from that study:
"However, when a dispersant is added, the film is removed and the film thickness stabilizes at a lower value. The antagonistic behavior of the detergents is well-known and one of the possible mechanisms was believed to be the competition between dispersant and ZDDP modecules to absord on availble surface sites." And it continues in more detail ...
My point is that this whole BITOG mentality of "if some level of characteristic is good, then more of it MUST be better" is total hogwash. While it may be true in some circumstances, there are ALWAYS trade-offs in almost any product. The "better" products, strike a nice balance in their performance, due to a well met level of achievement, relative to the design intent. High end synthetics such as Amsoil can last a very long time and do a great job; we've seen many supporting UOAs that prove this. But, they can also be of no benefit, and actually detrimental (not harmful, but in comparison to the alternative) in shorter OCIs. They likely will not clean any better, because they cannot affect the contamination rate. And the heavy dose of cleaning package they carry is detracting from the very anti-wear layer that is so important, which is probably why most syns (PCMOs and HDEOs) don't really show any "improvement" in wear reduction in short-to-moderate OCI durations versus a decent dino oil.
I would challenge anyone to show proof of claim that a syn is going to clean better in a normal OCI:
1 - how do you define clean?
2 - how do you measure clean?
3 - what proof (studies or UOAs) do you have that substantiates the claim inferred?
4 - extra credit bonus question; what trade-offs are you willing to accept for "better" cleaning?
I am results-driven; I don't want to read marketing hype or see PDS/VOA data. I want to see the real-world proof of claim.
