Originally Posted By: madRiver
Skip the FIT there are far better and more comfortable cars for your type of commute. It will get old in FIT and you'll be back on what to get next. I'd look for a really comfy sedan that suits your fancy as they cheap at the moment as SUV are the making sedans less desirable.
You could also just hang onto the F150. Skip two cars unless you have money to torch and garage space to fill.
OP,
I drive a Toyota Yaris Sedan. It is just a bit more insulated than the Fit.
But, If you are in it for the long run, here are my numbers:
I bought it new (~$17k), paid 2 years the notes, then paid it off. only tires (4-once), oil+filters(3-6k miles), 1air filter and atf (I wanted to change it)
It is now with us in year 9, at around 57k miles.
This type of cars, if you have family or fiends with you, or just luggage/gear is not really confy to drive for long rides.
If you really want better, go up in class for the likes of Fusion/Fusion hybrid. they hold for a long time, drive better, more comfortable chairs.
Or just get a wagon used/new
But if you can make due with your truck, gas may be less then car payments + full coverage insurance.
Whatever you test, make sure you test it in the conditions you will be using it; if cars salesman gives you rough time, remind who has the money and who will be using it for a long time.
Good luck with your decision
