Originally Posted By: Chester11
2007 Mazda 6i (2.3).
Yep - understand, it's an older car that I kinda like messing with. No leaks, but I did find out that the in line check valve seems slightly restricted (it sounds a bit like a trumpet and not an easy flow). It appears that I have to replace the entire hose, which is $94! Mazda parts are somewhat challenging to find, but that is crazy. I also posted on a Mazda specific forum to see if they had ideas. I would hate to make a junkyard run for a hose.
Our late great 2001 Protege was running very roughly a few years ago, and generated lots of codes. I finally found that the underside of the corrugated air intake hose (which is after the MAF sensor and before the throttle body) had cracks in it, on the underside only. The result was that air was entering and not being detected by the MAF. Duct tape was a good temporary fix, and I did replace the hose a couple of days later. This is now one of the first things I look for when faced with a rough idle. This was the Mazda 2.0, not the Duratec 2.3, but the same principle will hold.
