Originally Posted By: IndyIan
Originally Posted By: mightymousetech
I run -3.0 on the rear of my 1er and see perfectly even wear.
Well I assume you're using the outside edge of tire vigorously fairly often to balance wear out...
What toe do you run on the rear though? near zero?
I run a little less toe in that my car calls for. I am actually using the specs for a 1M, which is about half the total toe in the rear. I have changed all my suspension arms to the 1M/M3 version, and run the same tire width as the 1M. In the front I run -2.4 camber and exactly zero toe.
Yes, the 1er sees some agressive driving, but I don't take it on the track anymore. I use the Civic for lapping fun. Even the Civic has significantly greater camber than stock, and sees even tire wear.
The way I think of tire wear, is think of an eraser on the end of a pencil. If you roll the pencil along a piece of paper on it's edge, how fast does it wear out? That is camber. If you drag the eraser along a piece of paper, that is toe.
Edit: Just checked my alignment notes.
Stock spec for the 135i is 0.10 - 0.20 deg toe in.
The 1M spec is 0.02 - 0.15 deg.
I am running 0.04 deg.
