Originally Posted By: Cujet
I agree with the above.
My wife turned my 09 F150 SuperCrew too sharp in the lot and hit a mushroom shaped steel bollard. She heard the noise and stepped on the gas..... It TORE open the entire side of the truck, wheel to wheel, ugh.
Anyway, I had it repaired and the Ford dealership used all new Ford parts, including a big panel to repair the side of the cab. Repair came out looking great. But a few years down the road, the doors don't close correctly, the door seals fall off as they reused them and they clips were weakened. Etc. The repair still looks great. The functionality is obviously not the same. As the re-installed plastic trim, the seals and the fit all need attention. At this point, nobody will cover it. Plus the vehicle is worth a whole bunch less!
That is due to laziness and incompetence, plain and simple. If repaired correctly, it will be perfect. My Caddy has had major body repairs-I was punted into a K-rail at 60MPH, and the car was bashed from the center of the front bumper to the left rear corner. Two parts cars later, the doors close tightly, all the panels line up (better now than when it left Clark Street), the alignment is dead-on, tires wear evenly. The only clue the car was wrecked that badly is that my 1979 has a 1978 grille. (The entire front clip is from a rear-ended 1978 Sedan de Ville.)
You could probably fix most of it yourself, simply by replacing the door seal clips and trim adhesive, and adjusting the door strikers.
