My 335 is at 187,000 and probably 80,000 on the current HPFP. Between this and the electric water pump with the same mileage, I'm wondering if I want to take it on a 2000-mile trip in December.
DriveHard said:Update...getting frustrated...
I drove the car to the shop last week. It continued to run worse and worse on the 15 mile highway drive to the point I had to downshift and keep the rpm's quite high to even get it there.
The shop replaced the fuel pump
Engine went from random misfires on most of the cylinders to only a misfire on cylinder 4
Spark plug was coated with carbon and the shop said the coil tested "sketchy"
Shop performed compression and leakdown testing on cylinder 4 - both checked out perfect
I figured it was carbon fouling causing that cylinder to misfire...asked them to put it back together and drove it home. Got 25+ mpg for the first time in a very long time. Besides the misfire on 4, seemed to be running pretty good.
Parked the car and ordered new plug and coil for cylinder 4.
Replaced them tonight...misfire persists.
Compression is good, fuel pressure is now good, new plug, new coil...it HAS to be the fuel injector.
Guessing the failure of the pump has wiped out the injector in 4...and probably damaged the others as well.
Going to replace either all 6, or start with number 4. I will keep you posted.
[/quote
I would replace #4 only at this time, maybe you will get lucky and that’s the only damaged injector. If money is no object then all is ok, but at this point you could be continuing to throw money at it when you are now down to for sure issues. No more guessing. #4 isn’t going to fix its self though, there’s no MMO/Injector Cleaners that will make it better.
