W WyrTwister Joined Jan 13, 2013 Messages 4,161 Location Texas Nov 26, 2017 #1 Would this cause a problem ? https://www.oreillyauto.com/detail/valvo...evrolet/caprice Thanks ,
C CharBaby Joined May 25, 2005 Messages 15,703 Location ROCHESTER, NY Nov 26, 2017 #2 No problems that I am aware of as I do it all the time. I use Mobil 1 75w90 LSD gear oil in my non LSD Firebird FORMULA in my sig and have also used it in my wife's previous Lexus AWD TC & Diff(non LSD). I bought a gallon of PEAK 80w90 LSD gear oil from Pep Boys for around $15/gal. I believe this was their regular price. IDK if PEAK has a 80w140 LSD. Last edited: Nov 26, 2017
W WyrTwister Thread starter Joined Jan 13, 2013 Messages 4,161 Location Texas Nov 26, 2017 #3 Thanks ,
K KD0AXS Joined Nov 13, 2012 Messages 2,535 Location Nowthen, MN Nov 26, 2017 #4 No problem, all it means is that the oil contains the friction modifier to make LS work properly. Won't hurt anything to have the friction modifier if you don't have LS.
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia Nov 26, 2017 #6 No, it won't cause any problem.
W WyrTwister Thread starter Joined Jan 13, 2013 Messages 4,161 Location Texas Nov 26, 2017 #7 Thanks , all ,
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia Nov 26, 2017 #8 Btw, what's the differential housing temperature recorded .... if you had done one?
T TinyVoices Joined Sep 12, 2016 Messages 527 Location Columbia, MD Nov 26, 2017 #9 No, it's usually the other way around that poses an issue.
W Whitewolf Joined Oct 5, 2006 Messages 2,912 Location MI, USA Nov 26, 2017 #10 It probably wont cause a problem but generally the FM's required for LS applications tend to detract from oxidation and seal performance.
W WyrTwister Thread starter Joined Jan 13, 2013 Messages 4,161 Location Texas Nov 26, 2017 #11 I found 2 quarts of the Valvoline ( which I linked to ) that do not say limited slip . At AAP + 20% online discount . Thanks ,
