Originally Posted By: Nate1979
Originally Posted By: geeman789
Originally Posted By: SHOZ
Yes I am aware of that but the oil filter with the high spec is the common filter used on 100s of engines. I can't believe that they all have high flow oil pumps.
Quite a few Mazda, Kias and Hyundais use this filter. Could it be the filter is so restrictive that it needs the higher setting?
Perhaps someone could define "high flow..." oil pumps ? Given the near identical nature of the lubrication system in virtually every new engine, does one engine oil pump really move dramatically more oil...? Or are we talking about a similar range, something like 6 - 8 gpm or similar. Does anyone have any actual numbers...
I own a Subaru, which is rumoured to have a high flow oil pump, and specs a 23 psi by-pass oil filter. But nothing I've seen confirms this with any data.
Here is a thread to keep you busy for a few days:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1410171#Post1410171
I got through a couple pages. Was there ever a consensus?
The SHO motors took thr Motorcrsft FL-400A FWIW.
