Here is my original thread:
Initial Kreen thread
Wanted to give some updates since then. As noted, my initial run of 1/2 quart didn't make much of a dent in the oil burning (still roughly 2k/qt). I've gone in a couple of directions, so this isn't something you can draw specific conclusions from.
At the end of the 1st run of Kreen, I ran a half can of B12 through it (cold start, 8 min), then drained it. The oil was certainly very dark at that time. This present oil change, I changed my oil from a semi syn (Shell) to T6 5/40, which I had left over from a sale. In went the last half-quart of Kreen.
Yesterday was the day I hit 1850 miles, so I wanted to check the level (using the same method of checking each time, sitting overnight in same place). To my great surprise, I am 1/8" of an inch from where I started 1850 miles ago.
You can draw your own conclusions, but something appears to be working.
