Mine has been in for 1 and a half years now, for only 8,000km. Still looks in good form. I have the cleaning kit standing by. MAYBE I'll clean this spring.
I agree with metroplex about the cleaning. Both of my K&Ns state the warranty is good for a million miles or 10 yrs or 25 washings. I clean mine about every 20k-30k miles (I think my manual says to change the paper filter every 15k).quote:
Originally posted by metroplex:
I would advise against frequent washings - Accel says their filters are good for up to 25 washings. ... I have yet to see conclusive evidence linking K&Ns to an increase of dirt/silicon in the engine. I have heard of blower impeller pitting from dirt that came through the K&N which makes these filters unsuitable for use in Forced induction engines.
I guess my limited experience with turbos has me at a disadvantage here. On my Saab, the turbo's well downstream of the filter, so the media only sees normal inlet air forces. The way the airbox is designed, there's no turbo-pressurized (vacuumized?) air directly striking the surface of the media. Basically, all it does is pull a greater volume of air thru the media, the same way a larger NA engine would. (That is, it sees the same air volume as if I put my K&N on a 3.0L 6cyl.) Since this engine's designed to have a turbo (as opposed to bolting one on after the fact), I'm sure the increased air volume was considered when filter size was determined.quote:
... with a blower or turbo, you're basically using compressed air to blast at the medium - NOT good with the K&N. ... The cost of buying a new paper filter for the Ford 4.6/5.4 on the trucks, Mustang GTs, and Cobras ADDS up. $16 for 1 replacement paper filter. ...
This is nowhere near the case. While in an intake, the air that is drawn though the filter is spread across the entire filter and the difference in pressure from one side of the filter to the other is negligible.quote:
So with a blower or turbo, you're basically using compressed air to blast at the medium - NOT good with the K&N.
I put the K&N FIPK on the first LT1 that I owned, it was a 95 Trans Am. With that mod and a catback I only went from 13.94 down to 13.77, so it wasn't a huge performance gain. I figure I got about 7hp from each mod.quote:
Originally posted by DABEAR95:
Patman, I think you would notice a nice difference with the K&N FIPK on the Firebird. I installed one when I installed my headers and it was night and day...
