Originally Posted By: Chris142
The Jeep 4.0 valve rotators won't totate the valves under 3500 rpm. Carbon will build up on the back of the valves and the gas will soak into that,boil off and cause a lean condition. Go take it for a spirited drive. Get it wound up and see if that improves it.
There is a TSB about that, I couldn't remember if it was for the 4.0 or 4.2.
I would run a can or two of combustion cleaner through it, maybe some water. I used to mix solvent and water together, it was something I read about in one of my engine performance text books 20 years ago.
