I recently changed out my front brake pads and rotors on my 2000 Camry which were factory original to the car. Front pads were replaced with Advics Ultra Premium, the rotors are Centric CTEK, new OEM Toyota anti rattle clips aka hardware, and Dorman slide pin boots.
I disassembled everything and cleaned it thoroughly in my parts washer. I used Sil-Glide to lube up the slide pins and also where the new brake hardware sits onto the bracket. I noticed after driving the car for almost 60 miles post install, I can still smell the brakes… I didn’t do a bed-in procedure as Advics calls for a “30/30/30” rule which in my experience takes care of itself in normal traffic conditions.
The new thing I noticed after install, and this happened twice today on two different occasions, is that when I released the brake pedal from a stop light to take off, I almost felt like a holding back, drag type feeling before the car started moving. This of course stirred my curiosity even though it happened twice… it wasn’t drastic but enough for me to notice it.. I didn’t feel this before.. The reason that I changed out my front brakes was because they were old and I’d always hear a metal on metal scratching type noise every 1 full revolution of the rotor..
Now I’m wondering if I have a lazy/sticking caliper and if that had caused the symptoms of the aforementioned old brake noise..
I jacked up the car, placed the vehicle in neutral and spun both wheels by hand and they spin freely without hesitation..
What do you all think about the wear marks on my old original rotors and do they seem to have any wear marks that indicate a sticking caliper?
