Originally Posted By: RallyMachine
Well I topped it off with some T6 last night and immediately noticed that the Rotella seemed far thicker than the Amsoil EFM even though they are the same weight. While the Amsoil used to flow easily down the fill tube, I had to slow down the fill of the T6 (and spilled everywhere in the process -____-) because it wouldn't flow down the tube as fast.
Checked the PCV valve and it still rattled, but cleaned it out with some MAF cleaner since I had it out. Slight pool of oil in the Intercooler/TB hose, but definitely not a quarts worth!
I plan on doing a full change of the T6 today, but I'm thinking that the Amsoil might have sheered too easily in my engine (or at least I hope so
). My last interval was understandably long, but even after adding nearly the entire capacity of the engine in make up oil, the weight was barely in spec of a 5w-40...
Amsoil likely uses a higher quality basestock (i.e. more group IV PAO and Group V POE) than the Rotella T-6 and this is why it flows much better at room temperature.
You do realize that Amsoil's EFM is a European Car Formula 5W-40 Synthetic Motor Oil with full-SAPS European Oil for European Gasoline and Diesel Engines - right?
