GenesisGuy70
Thank you all for the constructive responses. As I said I know this topic is brought up daily around here and can get annoying. So again, thank you.
I ended up getting PP in 5w30 with a Fram ultra. As was stated, I know the fuel will thin it out to some degree but I'll stay above a 20w. Seemed like the most logical decision. I did get just a minor whiff of fuel in the factory fill. Car was built in October of 2016 and had 200 miles on it when I purchased it last month.
Once the temps start to drop I'll probably dump it and run a mix of 5w20 and 5w30 just to help cold startups....but is probably unnecessary. Would prefer to run PUP and will probably order it from Amazon and have it ready to go. And I think I'm going to run Hyundai filters after this change. Consensus around here seems to be they're of good quality and comparable to FU anyways. OCI is going to be set at 6,000 from here on out.
How come 0w30 is hard to find? I think that'd be my definitive year-round grade if I could find it. Is there no practical benefit to an 0w30?
Will also run a PEA based cleaner every 5-7500 as well, in addition to the TT fuel. Though the owners manual says you only need to do one or the other might as well considering they're low cost.
