Originally Posted By: Onmo'Eegusee
Okay, It does not like the RTS. Its making MORE noise and not going as fast. Going to try M1 15W50.
Diagnosing Noise:
All kind of "noises"..
Then there are actual components like pumps, planets, final drives or even something like a valve buzz that can cause you to want to tear your hair out. The trick is to find a way to make the noise change, or stop, and then examine what this change did to affect the noise.
Pump noises are simple. They change when pressure changes.
Torque converter noises are easy to isolate. Since the entire converter (pump, turbine and stator) turns while the transmission is in park and neutral, a converter noise will go away in those ranges
These make the most difficult noises to diagnose. This is where it is important to remember the first rule: A component cannot make a noise if it is not moving.
Final drive noises are perhaps the easiest of all to diagnose. The noise will increase in pitch as vehicle speed increases
