how much oil in an ltz400?
Apple Valley, California
Changed the oil and filter in my new to me 07 ltz400. I drained the tank and the crankcase. The book says. 2.1qts.sticker on the quad saya 2000ml. I put 2 qts in it which would be 1912ml. I assumed this would get it on the stick atleast but it didn't. I kept adding and checking and it took almost 3 qts. An internet search only turned up threads about oil gushing out if overfilled. Thoughts?
Were you screwing in the stick to get a reading or just sitting it in and pulling it out? Some require you to screw it in fully.
Did you start it up and saturate the filter before you checked the level?
I've owned an LTZ400, but not for long and honestly can't remember how much oil it held. Go to a quad forum and ask the question, someone will be a current rider surely. Try this one: KFX450R forum good guys on there and I know several of them ride KFX400s, same quad.
I have an 07 LTZ400. It's 2100ml for an oil and filter change, per the service manual. You have to run it for a few minutes, then let it sit about 3 minutes, then check the oil level.
