2017 Hilander v-6; Correct oil capacity?
South Georgia
After oil and filter change dip stick shoes about 1/2 qt low after adding 6 qts. Manual calls for 5.8 qts. It's a 2017 Toyota Highlander V6. Which is Do I trust as correct, the manual or the dip stick?
It wouldn't surprise me if it needs 6.5qts. How does your manual state how to check the oil level?
I can't speak for all manufactures, but in the case of Ford and Nissan, the manuals basically stated that the listed capacity was for approximation purposes only, and the ultimate guide was the dipstick. I would suggest checking your owner's manual for similar language.
