Originally Posted by dave1251
Originally Posted by 2010Civic
Supports my decision to stick with OEM fluid.
Explain how? Is the static, dynamic coefficients of friction significantly different? Cooling properties? Seal conditioners.
In any case if you drive normally you can't go wrong with DW-1. Also there is the little fact that they use proprietary add pack items that nobody else uses.
