Originally Posted by slacktide_bitog
Hankook makes quality tires.
Another thing to keep in mind is that OE tires are not a good basis to judge a tire compoany on, since they are different than what they sell to everybody else, even when they share the same name. For example, an OE Hankook Optimo H426 that originally came with the car brand new from the factory is not the same thing as the "same" Hankook Optimo H426 you'd buy from your local tire shop, Walmart, or Tire Rack. The OE tires are usually inferior to the aftermarket tires because they select OE tires to be cheap.
Hankook's Kinergy GT will be a much better tire than the Hankooks you will be replacing.
For the size 195/65-15
Hankook Kinergy GT
Falken Ziex ZE950
Kumho Solus TA71
Cooper CS5 Ultra
Goodyear Eagle Sport AS
Also, FWIW, even Nexen is now an OE supplier to Porsche (and they are building a Czech factory). They will be OE on some Cayennes. While the rebadged Touareg is no 911, it is Porsche's best-selling model by far. And I consider Nexen to be a step below Hankook.
What proof do you have of this theory? Why would any manufacturer change machining a composition to mass produce the same model or version of anything?
Hankook Kinergy GT
Falken Ziex ZE950
Kumho Solus TA71
Cooper CS5 Ultra
