Originally Posted By: Alfred_B
Originally Posted By: bioburner
Trichinosis in pork in the US has pretty much been eliminated. Developing countries that may still feed raw meat to the pigs could well be a problem.
Stats I just dug up was the possibility of getting the bug from pork here in the US sold thru stores is 1 in 154 million
They deep freeze the meat and it supposedly kills the parasites
I don't think they freeze fresh meat between the packing house and the grocery store. Most of the trichinosis in the US has been eliminated due to following best practices at the pig farms. Floors with grates is an example to allow the poop to fall down beneath the pigs.
In cases where the meat is frozen, such as hams, there are regulations if you are using it as a kill step as part of your HACCP. Read below.
There is a time and temperature relation for that work. The colder it is the less time it has to be frozen. Sticking it in your freezer at home would take a couple of days. A webpage I found on the USDA website shows that it only takes 30 minutes to kill trichinae at -35 degrees F whereas it takes 106 hours to kill trichinae at 0 degrees F.
Originally Posted By: Virtus_Probi
Don't you have to cook your burgers to well done if you mix in pork?
Pork was the scary meat when I was a kid and my mom would cook it to death because she was worried about us getting sick, guess chicken has taken over as the meat to be wary of since then.
Yes, you have to. Ground beef is supposed to be cooked well done as well so it's not an issue. Pork is a much softer meat and the fat in it keeps the patty soft and moist.
Pork doesn't have to be cooked well done. Well done temperature wise is 165 degrees F. Pork (whole meat, not ground) only has be cooked to 139 degrees F to kill trichinae.
