Originally Posted By: Shannow
(I only shut off the engine, dropped it into Neutraal and pulled off the road, dropping a type K thermocouple down the dipstick tube....nothing as flash as yours).
Test A
Drive on the highway in "D", then repeat for same speed (same road load) in "2" 1,800 RPM versus nearly 4,000RPM, same road load. 95C in the first, 125-135C in the second.
depending on your data sampling rate, you can catch the temperature spikes easier when a car comes to a full stop or if it is immediately shut off after a heavy load. e.g. driving with relatively high rpm and then exiting the freeway to a red light.
Not only the coolant flow is minimal due to low (idle) or 0 (engine shut off) rpm, the airflow is minimal as well. This is even worse on hot summer days, everything will be baking including your poor battery!
