Originally Posted By: user52165
Originally Posted By: BrocLuno
OK, these others have discussed the wired and wifi side of things. But you asked about the home. So tell us more about the actual house?
Is it wood framed and wood sided?
Is it stucco? In 1959 they did not likely use small wire mesh to secure the stucco like they do now-days. It can easily kill a wifi signal.
What type of insulation does it have? If it has foil backed fiberglass insulation, it can also easily kill a wifi signal.
Does it have an asphalt shingle roof? Does it have an aluminized infrared barrier in the attic ?
Is it an open floor plan, or all doorways and halls?
Has the electrical been upgraded to actual ground 3-way outlets?
Has it had Cable TV installed in the past? In more than one room?
The wifi access point us best close to the load. The speed drops with distance. Sometimes it's best to place the access point in the middle of the bldg in the attic. Sometimes on an interior room wall. This depends on the construction we are dealing with ...
Are you serious? Unless this guy just bought Versailles, a modem supplied by his ISP will be fine.
Yes, I'm serious. I've had older homes with additions that would not pass a signal through the remodeled wall ... We positioned the access point on top of that wall in the attic to service both sides ...
It depends on what the broadcast lobe looks like. Some are fairly flat and some are very round. Round will go up or down one flight well. Flat oblong lobes work better in single story. There are even flat'ish panel access points that have little back lobe. They work from one wall onward well though
All of this effects speed. If your incoming cable is 100/Mbs and your access point can only make 56 due to signal loss, what are you paying for ...
Ethernet wired solutions go fast everywhere. They are just more trouble to install ...
Didn't ask - maybe he will have a basement that makes cabling easy
