I went to a gas station today that I normally do not go to, however I decided to try it anyway since the station had just been remodeled with new pumps and everything. So basically while I was there the cut off on the pump never kicked in, I spilled about a half gallon or so on to the ground. The gas that spilled came out of the center top of the gas tank instead of the filler tube, about the same location the vent line is connected to.
The attendant was pretty upset treating me like I was an idiot because he though that I spilled over 12 gallons of gas on the ground. He came out and was like "did you not see it all leaking out?!?!?!" I was driving my Tbird that has a 22 gallon gas tank and most coupes now have only 12-16 gallon tanks. It was only overfilled a gallon max, I guess he just doesn't know what 12 gallons of gas would look like if I did actually overfill it that much.
Has anyone ever had a modern gas pump like this not kick off?
Also why would it blow the vent off? Shouldn't it spill out of the filler tube?
