I was looking at these products and noticed the hole is smaller than the drain hole. Usually the drain hole of an oil pan is at the lowest point. With the smaller hole in the valve, effectively moving the drain hole height upward. Wouldn't use of these valves trap dirt and oil in the bottom of the pan everytime?
I did see this in Fumoto's FAQ:
Q. Does my Engine Oil Drain Valve protrude into the interior of the oil pan and prevent full drainage of my engine oil?
A. No. The threaded oil drain plug hole is always reinforced to accept the threaded bolt of the drain plug. In most cases, the Engine Oil Drain Valve will not extend past this threaded portion of the drain hole and will allow the oil to be properly drained. Your Engine Oil Drain Valve will let you drain your engine oil while it is hot without burning your hands and it is much more effective than trying to pump the oil out from above.
It says "in many cases"... how can one be sure?
[ March 01, 2003, 10:24 PM: Message edited by: S2000driver ]
