Originally Posted By: HX520W
Originally Posted By: AirgunSavant
Did you use old motor oil to oil the gasket when you first installed it???
I used fresh oil on the gasket before installation.
Why would it matter if it's fresh or used?
As far as I'm concerned that rust is not an issue, but the glue flake is, as it could go past the filter (in a bypass situation) and then block oil flow to some part of the engine, then kaboom
