Originally Posted By: sayjac
Originally Posted By: GSCJR
You were probably looking at PH9837 which is w/o adbv. PH3675 is w/adbv for that application.
I believe you are on to something here.
My interest piqued here, I decided to do more research on the adbv/no adbv filter applications is it applies to this engine/vehicle, ie., GM 4.2L 6cylinder TrailBlazer.
Using the Fram look up, it seems that depending on the year there are two or three filters that can be used for this application. The 02-04 shows PH3675 or alternatively the shorter (-.75") PH3506 can also be used. Both do have an adbv.
For the 05-09 model years the topic'd PH9837 with no adbv is shown as filter for the this application. Accrding to look up, it has the same outer dimensions as the PH3675.
Otoh, Purolator and Wix (using their respective catalogs) make no distinction between model years, they spec one filter which has an adbv. In the Purolator it's PL/L25288, in the Wix it's the 51522.
Also according to the Fram look up, the ACDelco cross reference to the PH9837 is the ACD PF61/(E). If one does a Google image search of the PF61 they all (ecore or classic construction) appear to show an adbv on the filter. The best site I found is linked below with excellent pics of the ACDelco and other filters for similar GM application. It also shows dissection pics of the PH3675, TG3506 and many others.
So based on this, if I was chosing from the Fram filters for any 4.2L 6 cylinder application, I would go with the PH/TG 3675 with an adbv. Just me. While an adbv may not have been OE spec, there's nothing lost by having one. And it appears the PF61 uses one now.
PF61 19256044 (classic)
PF61E 19210285 (ecore)
PF61 19210285 ( no E suffix) Ecore
GM oil filter application dissection Home Page.
Well I already went to AAP and bought a PF61 and I took pics
Here is one pic and this is a real pic, not one I found online, its the real filter with me holding it.
I called up AAP and asked the sales person if this was the E-Core or the older ones
and he said there are only E-CORES sold at this time and said the E-Cores are more updated
here is a 2nd pic of it.
Also I think it has a ADBV, notice the rubber
However I was told if the box says professional and has no E after the model number then its NOT a E CORE..
So if this was a E core it would be PF61E and as you can see this is not.
